BTanner
4 years agoHPS unused IO Access on Arria 10
I can add .gpio_x_pad_out_export and .gpio_din_export to HPS Sys, but the Interface Planner only allows pin selection for the Bank 2L GPIO1_IO23..0. It doesn't allow selection of the unused pins of G...
- 4 years ago
I understand now, however in your case, in the documentation stated that:
There are 48 HPS peripheral pins that are shared with the FPGA core. They are divided into four quadrants of 12 signals per quadrant. Each quadrant can be assigned to the HPS or the FPGA fabric.
In each shared I/O quadrant, all 12 I/Os are assigned either to the FPGA or to the HPS. It is not possible to divide the I/Os in a quadrant between the FPGA and HPS.
So if you must, you have to have all the HPS' 12 I/Os on one quadrant in order to use the maximum 3 quadrant for FPGA.
Reference:
https://www.intel.com/content/www/us/en/docs/programmable/683711/21-2/shared-i-o-pins.html
BTanner
4 years agoThanks for the help.
Here is the project and screen shots of the various Parameter Tabs.
