12 years agoYou can do it using Quartus Backannotate feature.
First compile your design (synthesis + fit). Then enable backannotate in Assignments-> Back Annotate Assignments dialog. Save the project. Quartus will add all nodes of your design along with their locations: LABs, FFs, PLLs, Transceivers. Find the node you're interested in, and changed to the desired location. Remove the rest of the backannotated constraints. Thanks, Evgeni
