How to get QSYS to propagate SYSTEM_INFO GENERATION_ID value into composed component
I have created a _hw.tcl component which is a "composed" component that assembles a number of other components into the hierarchy.
One of those components happens to be the altera_avalon_sysid_qsys_hw.tcl component.
This component assigns its instance parameter "timestamp" from the SYSTEM_INFO GENERATION_ID value.
When the altera_avalon_sysid_qsys_hw.tcl component is instantiated directly in my top level QSYS file, the "timestamp" parameter is properly generated.
When that same component is instantiated via my "composing" component, the timestamp is zero.
I cannot have my componsing component "set" that parameter because it is declared as "derived".
How do I get QSYS to propagate the GENERATION_ID into the composed component?
thx,
Dave Cattley
- Nurina
Hi, I've reported this problem to our internal team. I will let you know of any updates.
- Nurina
Hi, please note that we are currently investigating the problem. I will let you know if we have any updates.
Nurina
- Nurina
Nurina
- dcattley
Ok, thanks.
- Nurina
Nurina
- Nurina
We had feedback this issue to our engineering. However, due to different priority on hand in engineering, the fix will take some time. We are sorry to inform this.
I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
