9 years agoHow to generate two non overlapping clock signals from single clock?
In a design I'd like to use both edges of an external clock signal (EXT_CLK). No other clock signals are available. Now the question: Is it possible to generate two signals CLK1 == EXT_C...
9 years ago --- Quote Start --- Doing logic with the clock is pretty much a no-no in FPGAs. The skew will just kill it. Why not just derrive a 2x EXT_CLK using a PLL? You can lock the PLL so that it is in sync with EXT_CLK. --- Quote End --- Thanks for the answers! The FPGA should connect to an old system that is using a two phase non-overlapping clock and this clock is too low to be used for the PLL. Just a last question (for now): What is better if I want to use both edges of the clock in a design: 1. using always @ (posedge CLK) and always @ (negedge CLK) or 2. using @ (posedge CLK) and @(posedge CLK_n) 3. both variants 1+2 are just equivalent? Thanks!
