hzs268
4 years agoHow to fix lut4 input ports?
I need to implement a arbiter puf in cycloneive fpga, with the requirement of extreamly net delay parameter about less than 100ps.
I know that chip planner can change the lut input port in gui di...
sstrell
4 years agoCan you better explain what you're trying to accomplish here? What is an "arbiter puf"? You should be looking at your HDL code and timing constraints, not trying to make low-level post-fit changes.
