ahmedhs
4 years agohow to find the area in slices and the frequency in MHz
Is there a way to find the area and frequency after compiling a code?
If there is how?
ak6dn
4 years agoAfter you are done compiling, look in your design directory.
The DESIGN.fit.rpt will give you the exact usage summary of logic cells, memory, I/O, etc.
The DESIGN.sta.rpt will give you the timing analysis, predicting the maximum clock rate of the design, and worst case critical paths.
- ahmedhs4 years ago
Thank you for your response
But I also want to ask when I open those files do I need to calculate something to get the area and frequency or is it written directly
I uploaded the files if that would help you answer
