How to constraint the min delay?
- 4 years ago
I haven't try to constrain a delay between combinational logic. Have you try to use the set_data_delay before?
I don't think the set_net_delay works with comb. logic but you can check the Ignored SDC Report and see whether the constraints have been applied in your design.
There is a duplicate case with the same issue. Please refer to the case below (link attached) for further support.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos and select the best solution.
Hi RichardTanSY_In
Thank you, RichardTanSY_In
Unfortunately, Quartus13.1 seem that don't support set_data_delay command.
I will continuous follow the other one case.
Thank you very much.
