How to constraint min delay between LCELLs?
- 4 years ago
Right so I don't think this constraint works on LCELLS alone. Because you would need a setup/hold relationship in the first place.
Which brings us back to using set_data_delay, which definitely should work on LCELL alone.
Since it isn't supported on Quartus II 13.1, I suggest you migrate to Quartus Standard 21.1 as this would have the set_data_delay.
On the other hand, you are using LCELL to generate a pulse to wake up the clocks right? Maybe you could consider using clock control IP: https://www.intel.com/content/dam/support/jp/ja/programmable/support-resources/bulk-container/pdfs/literature/ug/ug-altclkctrl.pdf
Nurina
No problem! I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution.
- NuvKFC4 years ago
Contributor
Hi Nurina
Thank you, Nurina, very much.OK. No problem! Thank you very, very much.
