How to constraint max skew between two net or balance the delay between two net?
- 4 years ago
You may refer to this video on how to constraint your design: https://www.youtube.com/watch?v=ggWxledaBFg
Nurina
Sorry about that. Let me try to re-upload it.
- NuvKFC4 years ago
Contributor
Hi Nurina
Thank you, Nurina, very much.
Data_a and Clock_a are in the same clock domain. So, R1 and R2 should meet the setup and hold timing.
If I constraint the skew between R1 and R2 on the previous picture, how to know the path delay (PAD1 to Clock_a, PAD2 to Data_a) meet the requirement?
I only constraint the net delay as follows on the paths which are from PAD1 to Clock_a and from PAD2 to Data_a.
Constraint:
set_net_delay -max 5.0 -from PAD1 -to clock_a
set_net_delay -min 0.0 -from PAD1 -to clock_a
set_net_delay -max 5.0 -from PAD2 -to data_a
set_net_delay -min 0.0 -from PAD2 -to data_a
