NuvKFC
Contributor
4 years agoHow to constraint max skew between two net or balance the delay between two net?
I have two end point (two path) that need to balance the delay.
The design is as follows.
Path1:
PAD1-->clock of module A: clock_a
Path2:
PAD2-->data of module A: data_a
How t...
- 4 years ago
You may refer to this video on how to constraint your design: https://www.youtube.com/watch?v=ggWxledaBFg
Nurina
Nurina
4 years agoHi,
I think you're suppose to add set_max_skew to the registers R1 & R2 like in this picture:
So then the command should be like so:
set_max_skew -from R1 -to R2 1.0
Nurina
NuvKFC
Contributor
4 years agoHi Nurina
Thank you, Nurina, very much.
I can't see the picture. And sorry that I didn't quite catch your point.
Where are the R1 and R2 in my design?
I can't find any register (R1, R2) on the path from PAD1 to clock_a (Path1) and the path from PAD2 to data_a (Path2).
Thank you very much.
