How to constraint max skew between two net or balance the delay between two net?
- 4 years ago
You may refer to this video on how to constraint your design: https://www.youtube.com/watch?v=ggWxledaBFg
Nurina
Thank you for the clear explanation.
You may find this training video useful: https://www.youtube.com/watch?v=RTcZOl2e8PI
You will have to add a synchronizer chain after path 1 as mentioned in the training video.
Could it be that the set_net_delay constraint is ignored because of a typo? It should be like so, it needs to be "-to" not "to":
set_net_delay -max 5.0 -from PAD1 -to clock_a
For set_max_skew you can try this rather than derive a value as mentioned in the video:
-get_skew_value_from_clock_period
Nurina
Hi Nurina
Thank you, Nurina, very much.
Yes, to is a typo.
And how to constraint the path from PAD1 to clock_a (Path1) and the path from PAD2 to data_a (Path2)?
Path1 and Path2 aren't a grouped paths, like R2 to R3 in the video.
I had tried following constraint. But "report_max_skew" command don't report any path.
Constraint:
set_max_skew 1.0 -from [get_ports {PAD1 PAD2}] \
-to [get_nets {A|clock_a A|data_a}]]
