JSLY
4 years agohow do i set quartus to compile VHDL to 2008, tool can't find library float_pkg
I am using quartus prime lite v 21.1 and trying to compile / synthesize and get error
10481 VHDL use Clause error: design library "ieee" does not contain primary unit "float_pkg"
If i look at t...
leonardo_forum
4 years agoHello,
You can add the VHDL-2008 Support Library to your project (files fixed_pkg_c.vhdl and fixed_float_types_c.vhdl) and add this declaration:
library ieee_proposed;
use ieee_proposed.fixed_pkg.all;
The library is available at https://github.com/FPHDL/fphdl
Cheers
