9 years ago
How do I convert verilog file to board symbol file using quartus?
To convert the *.v file to *.bsf, I tried to go to File -> Create/Update -> Create Symbol Files for Current File. But this option is greyed out. I'm using Quartus version 16. I remember this was possible with some earlier versions. Any hints/suggestions on how I can convert *.v to *bsf in newer versions of Quartus?
    Boy, I'd be really irritated if I bought the Pro version only to find out it has LESS features than the Standard edition!
    I have no problem doing this with Quartus 16.1. Is your .v file open and in the active window?
    Got it. Thank you. I just checked it is working with the standard edition but it is greyed out only in the pro version. Is your Quartus a standard edition one? Do you know how to enable it in the Pro version?. Most of my other design is created using pro version.
    Yes, standard edition. I don't know anything about Pro.
    Quartus Pro version will have this option grey out, unfortunately, currently the only way to use this is by using the standard edition.
    kentan
    --- Quote Start ---
    --- Quote End ---
    Afaik, The pro version is a rebuild of the current engines and only supports the newest families. The people that use these are unlikely people who use schematics and hence the problems supporting them.
