16 years ago --- Quote Start --- I can compile it in quartus , also I can see the result using waveform. but I can't uploaded it to fpga. when I click on "add file" in "programmer" window I don't see the file. I have tried to get the license twice, now I have to license files and non of them is working. about MAC address, I get it from "command" ( dos window) then " ipconfig/all" I don't now what is the problem thanks any way... --- Quote End --- So I don´t know if I´m right but it seems there is no .sof file. If this is right it is cause there is something wrong with your license file. Quartus compiles everything except these .sof files if you have no license file. Do you have more than one LAN adapter. You must choose the Ethernet adapter and not the Wireless adapter. Maybe thats the fault.
