NM8
7 years agoHaving issue with installation for Quartus 19.1 Prime Pro with error "Can't open editor -- can't load library "pgm_pgmwq.dll". The specified module could not be found."
Hi, I got the error stated above and when checked the file exists. Then on checking got a link having a workaround https://www.intel.com/content/www/us/en/programmable/support/support-resources/k...
- 7 years ago
Hi Nanjunda,
Is your dll issue solved by reinstalling? I have installed the Quietus 19.1 pro on windows 10.i did not face any issue.
Regarding driver installation it may fail if the required driver already installed try by manually installing.
Attached the image
Anand
NM8
7 years agoHi Anand,
Thanks for the info.
Yes we tried in other machine and its installing properly.
Not sure what's wrong with my machine.
Thanks for the support.
Nanjunda M
BoonT_Intel
5 years agoHi, I am facing the same problem and able to fix it if I install it using administrator access (right-click the installer and run as administrator).
