NM8
7 years agoHaving issue with installation for Quartus 19.1 Prime Pro with error "Can't open editor -- can't load library "pgm_pgmwq.dll". The specified module could not be found."
Hi, I got the error stated above and when checked the file exists. Then on checking got a link having a workaround https://www.intel.com/content/www/us/en/programmable/support/support-resources/k...
- 7 years ago
Hi Nanjunda,
Is your dll issue solved by reinstalling? I have installed the Quietus 19.1 pro on windows 10.i did not face any issue.
Regarding driver installation it may fail if the required driver already installed try by manually installing.
Attached the image
Anand
NM8
7 years agoHi Anand,
I tried the disconnecting network and installing the same machine I see still the issue exists.
I'll try it with different machine.
I have attached a screenshot of the issue in driver installation.
Thanks & Regards,
Nanjunda M
AnandRaj_S_Intel
7 years agoHi Nanjunda
Let me try to install from my side.
I will update you the status.
Anand
