Having issue with installation for Quartus 19.1 Prime Pro with error "Can't open editor -- can't load library "pgm_pgmwq.dll". The specified module could not be found."
- 7 years ago
Hi Nanjunda,
Is your dll issue solved by reinstalling? I have installed the Quietus 19.1 pro on windows 10.i did not face any issue.
Regarding driver installation it may fail if the required driver already installed try by manually installing.
Attached the image
Anand
Hi Nanjunda,
May be due antivirus software contact your IT.
To confirm that, can you disconnect from office network and launch Quartus as administrator.
If same issue is faced try by installing it in different machine.
Anand
Hi Anand,
I tried the disconnecting network and installing the same machine I see still the issue exists.
I'll try it with different machine.
I have attached a screenshot of the issue in driver installation.
Thanks & Regards,
Nanjunda M
- AnandRaj_S_Intel7 years ago
Hi Nanjunda
Let me try to install from my side.
I will update you the status.
Anand
Hi Nanjunda,
Attached the image
Anand
- kentlian4 years ago
Hi Anand,
I Checked this topic.
Actually I have exactly the same issue like you.
I read the discussion, but It seems I don't see the solution.
Installing Quartus 19.1 Prime Pro on Windows 10 is really headache to me..
I installed Quartus on 4 PCs successfully but on 2 PCs failed.
Today I tried to install on 7th PC and met the same issue "Can't open editor -- can't load library "pgm_pgmwq.dll". The speccified module could not be found"
May I ask for you sharing the experience ? Thanks.
Kent
