16 years agogetting quartus warnings
Hi,When I compile my design I keep getting warnings like this:
Warning (14110): No clock transition on "CMD_DECODE:u2|oTxD_DATA[6]" register due to stuck clock or clock enable Warning (14130): Reduced register "CMD_DECODE:u2|oTxD_DATA[6]" with stuck clock_enable port to stuck value GND My design doesn't function so I believe I should solve this warnings.I checked my source code again and again and it seems fine to me.I don't understand why the clock is stuck.How can I sort those warnings out?:confused: I'm using quartus 7.2, source code in VHDl: entity CMD_DECODE is port( iCLK: in std_ulogic; iRST_n: in std_ulogic; ----------USB JTAG---------- iRxD_DATA: in std_ulogic_vector (7 downto 0); oTxD_DATA: out std_ulogic_vector (7 downto 0); iRxD_Ready,iTxD_Done: in std_ulogic; oTxD_Start: out std_ulogic; ---------REG---------------- iREG_DATA: in std_ulogic_vector (15 downto 0); oREG_DATA: out std_ulogic_vector (15 downto 0) ); end entity CMD_DECODE; architecture behav of CMD_DECODE is shared variable CMD_Tmp: std_ulogic_vector (63 downto 0); shared variable mREG_STEP: natural range 0 to 5; shared variable mREG_WRn,mREG_Start,mREG_RDn: std_ulogic; shared variable f_SRAM: std_ulogic; ----------USB JTAG TxD Output shared variable oREG_TxD_Start: std_ulogic; shared variable oREG_TxD_DATA: std_ulogic_vector (7 downto 0); signal CMD_Action: std_ulogic_vector (7 downto 0); signal CMD_Target: std_ulogic_vector (7 downto 0); signal CMD_ADDR: std_ulogic_vector (23 downto 0); signal CMD_DATA: std_ulogic_vector (15 downto 0); signal CMD_MODE: std_ulogic_vector (7 downto 0); signal Pre_Target: std_ulogic_vector (7 downto 0); begin CMD_Action <= CMD_Tmp(63 downto 56); CMD_Target <= CMD_Tmp(55 downto 48);--SRAM CMD_ADDR <= CMD_Tmp(47 downto 24); CMD_DATA <= CMD_Tmp(23 downto 8); CMD_MODE <= CMD_Tmp( 7 downto 0);--NORMAL Pre_Target <= CMD_Tmp(47 downto 40); ----------Shift Register For Command Temp---------- process(iCLK,iRST_n,CMD_Action,iRXD_Ready,Pre_Target,CMD_MODE,CMD_Target, CMD_DATA,iTxD_Done,iREG_DATA) begin if rising_edge(iCLK) then --= '1' or f_iRST_N = '1' if iRST_n = '1'then if CMD_Action = X"94" then mREG_RDn := '1'; elsif CMD_Action = X"83" then mREG_WRn := '1'; end if; if iRXD_Ready = '1' and Pre_Target = X"A5" then f_SRAM:='1'; if f_SRAM = '1' then case mREG_STEP is when 0 => if CMD_MODE = X"AA" and CMD_Target = X"A5" then --check cmd mode NORMAL and target SRAM oREG_DATA <= CMD_DATA; mREG_Start := '1'; mREG_STEP := 1;--go to case'1' else mREG_STEP := 0;--cease here f_SRAM := '0'; end if; when 1 => if mREG_RDn = '1' then --if READ mREG_STEP := 2;--go to case'2' else mREG_STEP := 0;--if WRITE f_SRAM := '0'; mREG_Start := '0';--go back 0 end if; when 2 => oTxD_DATA <= iREG_DATA(7 downto 0);--read FIRST BYTE from iREG_DATA oTxD_Start <= '1'; mREG_STEP := 3;--continue processing to next case when 3 => if iTxD_Done = '1' then --if tx done then stop tx oTxD_Start <= '0'; mREG_STEP := 4;--continue processing to next case end if; when 4 => oTxD_DATA <= iREG_DATA(15 downto 8);--read NEXT BTYE from iREG_DATA oTxD_Start <= '1'; mREG_STEP := 5;--continue processing to next case when 5 => if iTxD_Done = '1' then mREG_Start := '0'; oTxD_Start <= '0'; mREG_STEP := 0 ;--go back f_SRAM := '0'; end if; end case; end if; end if; else mREG_RDn :='0'; oREG_TxD_Start :='0'; mREG_WRn :='0'; mREG_Start :='0'; f_SRAM :='0'; mREG_STEP := 0 ; end if; else null; end if; end process; end architecture; It is supposed to transmit data from CMP_tmp to oREG_data when CMP_action is WRITE. If CMP_action is READ it transmits data from iREG_data to oTXD_data.
