12 years ago
Generating Random Byte values
I am writing vhdl process that can generate random 8-bit(1 byte) values so that I can send that values to RAM which has 10 addresses. How can I do?
    if it is only for simulation, then you can use the uniform procedure from the math_real package. It generates random values in the range 0 - 1 that can then be used to scale other number. For example:
    use ieee.math_real.all;
    variable seed1, seed2 : positive;
    variable rand  : real;
    variable rand_int : integer;
    uniform(seed1, seed2, rand);
    rand_int := integer( trunc(256 * rand) );
    Remember, this code cannot be synthesised into an FPGA.
