--- Quote Start ---
Hello guys,
I have this issue. I have in the process declarations 2 varaibles of type FILE :
MODULE(A)
PROCESS(clk)
FILE ei : text IS OUT "ei.txt";
FILE ej : text IS OUT "ej.txt";
begin
This module is generated in the top level entity several times. Each module has its own ID.
Do you know how to generate a different file name for each module?(something like for the first module ei_1.txt ej_2.txt)
--- Quote End ---
Try this:
signal id_str : string(1 downto 1) := "1";
signal filename : string(8 downto 1) := "ei_" & id_str & ".txt";
if your id is integer input you need to have function to convert it to string
