11 years agoDepending on the size of your stimulous waveforms, the easiest way is to just set them up as a ROM in the FPGA, and have a simple state machine that addresses the rom to drive the outputs. I wouldn't bother with the SDRAM unless the size of the files are larger than what will fit into the internal rams of the FPGA.
Pete
