WNC_HowardHuang
3 years agogate level simulation with fiftyfivenm_atom_pack library not found
Dear all,
we tried to do post-simulation through Quartus standard 20.1
using ModelSIM as simulator
FPGA device is 10M04DAU324C8G
Here's our step for doing simulation
1. generate a new proj...
RichardT_altera
3 years agoI have attached a simple design with testbench so you can successfully run the gate-level simulation using Modelsim or Questa.
- Open the simple_design.qar and change the EDA executable paths to a valid path.
- Run EDA Netlist Writer.
- Run Gate-level simulation.
You can compare it with yours to check the simulation flow.
I recommend to upgrade the design to the latest Quartus Standard version 22.1 and the simulator tool to Questa instead of Modelsim, as Modelsim has been obsolete from Quartus Pro 20.3 or Quartus Standard 21.1 onwards.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
