12 years ago
Function to_unsigned
I've got some problem to use the function to_unsigned.
I create a program that take two inputs from switch, convert into 7 segment display and show on it.
Then i start a process in which i want to sum each input and show the result on 7 segment.
but when i use the function to_unsigned on this part of code i've got an error
temp <= input1+input2;
result <=to_unsigned(integer(temp));
segmentsR <= unsigned_to_seven_segment(value =>unsigned(result), number_of_digits =>2, value_is_bcd =>false);
The error is:
- formal port of parameter "SIZE" must have actual or default value
So i see on the ieee library what SIZE means and i saw that after ARG is necessary to write, SIZE .......
I try to modify the code in this way
result <= to_unsigned(integer(temp, SIZE:NATURAL));
Now the error is near text ":"; expecting ")" , or ","
What means? Is there anyone can explain me what is SIZE?
MAT
