16 years ago --- Quote Start --- their politely stated response was use a MAX II to implement a usb blaster --- Quote End --- Did they suggest to "abuse" an existing development kit MAX II factory image or presented another idea where to get the undisclosed USB Blaster design? --- Quote Start --- the Bemicro board if I'm not mistaken uses the FT2232L which is not recommended for new designs. --- Quote End --- It uses FT2232D on recent revisions. It may be the case, that the driver can work with High Speed FT2232H as well, but it surely won't support higher JTAG clock speeds than 6 MHz without being rewritten, so there's probably no benefit, just an increased current consumption.
