8 years agoforce_type confusion
Hi, For the “force” command there are three major types: deposit/drive/freeze. I got confused and could not find authoritative definition. Please confuse me if I am wrong: Differe...
8 years agoI did ponder on your answer carefully, but still have questions.
Failure 1: In real circuits, different module/block execute in parallel. But in modelsim, as all were compiled and executes linearly according to a state machine, I doubt if “ambiguity/contention” can be simulated. For example in a contrived example: reg r1_reg; output r1; always @ (posedge clk) begin r1_reg<=1; end always @ (posedge clk) begin r1_reg<=0; end assign r1=r1_reg; as we run it, we always hit the first "always" before the second, so r1_reg forever is 0. Since HDL compiler always need to sort/give order to blocks before they can be arranged to execute, perhaps it is unavoidable and we could never easily simulate such racing/contention? Failure 2: wire, tri, wand,wor,buf,not: grammars of all these gates in Verilog are limited to strict logical expressions (+, &&, ^ operators, etc. Could you give counterexample?), and we failed to construct ambiguous drivers with this. Failure 3: input a0,a1; output a2; assign a2=a0; assign a2=a1; Quartus compiler fail and gives “a2 already assigned to a0” remark. Could you give nontrivial example to contrive multiple driver ambiguity in Verilog, and give remarks to the 3 failure above? greg
