10 years agoForce synthesis to fail if RAM cannot be inferred?
Hi, we have a design where there are a few large memories, declared as verilog reg[][]'s, which must be implemented as M9Ks. The design can't possibly fit the device or meet timing if they are imple...
10 years ago --- Quote Start --- If you're going to do that, you might as well just instantiate the ALTSYNCRAM directly. The only time I see using a parameterised module like this being useful, that simply infers a ram internally, is when you need cross vendor compatibility. Because using the megawizard doesnt let you paramterise your block, or use your design in another vendor's tools. --- Quote End --- I'm glad at least one person here understood my question.
