PhilipJ451
4 years agoForce Quartus to keep a signal for SignalTap to use
I am hoping someone may have an answer to a problem I have wrestled with for a long time.
I make a lot of use of SignalTap to analyze what is going on inside my FPGA design but so often I fin...
sstrell
4 years agoI'm presuming you are using Quartus Standard because that's a Cyclone V device. Pro now has the new "preserve for debug" feature just for this issue.
Are you trying to tap pre-synthesis or post-fit nodes? I'm presuming post-fit because if you tap pre-synthesis nodes, they should be preserved through compilation. If you can, try using the Signal Tap pre-synthesis filter in the Node Finder when you tap nodes and see if that makes a difference.
