PhilipJ451
4 years agoForce Quartus to keep a signal for SignalTap to use
I am hoping someone may have an answer to a problem I have wrestled with for a long time.
I make a lot of use of SignalTap to analyze what is going on inside my FPGA design but so often I fin...
MathiasB
4 years agoHi,
I think it may depend on how you add signals to your Signal Tap.
First you do not need to run the whole compilation, just elaboration is enough (saves a lot of time).
Then when you use the Signal Tap's node finder, select "Signal Tap: pre-synthesis" in the filter options.
Save and do full compilation this time. It should work. At least this is what I do, though I do not think I have unused internal logic to monitor in my designs.
Hope that helps
