11 years agoFind parameter names on an an entity
can someone please tell me how to find the (internal?) parameter names that Quartus uses? For example, when I was looking for help with creating clocks for TimeQuest for an LPM_Counter, I was pointed to things like : {lpm_counter0:Clock_Divider|lpm_counter:LPM_COUNTER_component|dffs[4]} as the clock target Where lpm_counter0 is a custom LPM counter type Clock_Divider is the instance name And dff[4] is the port that I want to write the counter to. However, I don't know how I could have found this for myself. The LPM_Counter has ports name CLK and q[0..x], it turns out that dffs[4] is equivalent to q[4], but how would I know that? Where is dffs[] defined? My specific problem at the moment is that I have an input pin that is used in a small piece of custom VHDL. The output from the VHDL block is used as the clock input for a 74273 function block TimeQuest identifies the input pin name as a clock signal that I need to create a clock for. So, I assume that I need to create a clock for the CLK port of the 74273 Using the Counter example, I guess that I need something like the Block type (74273?) : Instance Name | [some attribute name][some index name]? Is there a Quartus manual or help file that tells me how I can find parameter names on blocks that are different to those shown on the parameters/pins display? regards Dave
