Error(10327)cant determine definition of operator"="-found 0 possible definitions
LIBRARY IEEE;
LIBRARY ALTERA_MF;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE ALTERA_MF.ALTERA_MF_COMPONENTS.ALL;
ENTITY SCOMP IS
PORT(
CLOCK : IN STD_LOGIC;
RESETN : IN STD_LOGIC;
PC_OUT : OUT STD_LOGIC_VECTOR( 9 DOWNTO 0);
AC_OUT : OUT STD_LOGIC_VECTOR(15 DOWNTO 0);
MDR_OUT : OUT STD_LOGIC_VECTOR(15 DOWNTO 0);
MAR_OUT : OUT STD_LOGIC_VECTOR( 9 DOWNTO 0);
IO_WRITE : OUT STD_LOGIC;
IO_CYCLE : OUT STD_LOGIC;
IO_ADDR : OUT STD_LOGIC_VECTOR( 7 DOWNTO 0);
IO_DATA : INOUT STD_LOGIC_VECTOR(15 DOWNTO 0)
END SCOMP;
ARCHITECTURE a OF SCOMP IS
TYPE STATE_TYPE IS (
RESET_PC,
FETCH,
DECODE,
EX_LOAD,
EX_STORE,
EX_STORE2,
EX_ADD,
EX_JUMP,
EX_AND,
EX_SUB,
EX_JNEG,
EX_JPOS,
EX_JZERO,
EX_OR,
EX_XOR,
EX_ADDI
SIGNAL STATE : STATE_TYPE;
SIGNAL AC : STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL IR : STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL MDR : STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL PC : STD_LOGIC_VECTOR(9 DOWNTO 0);
SIGNAL MEM_ADDR : STD_LOGIC_VECTOR(9 DOWNTO 0);
SIGNAL MW : STD_LOGIC;
BEGIN
MEMORY : altsyncram --Use altsyncram component for unified program and data memory
GENERIC MAP (
intended_device_family => "Cyclone",
width_a => 16,
widthad_a => 10,
numwords_a => 1024,
operation_mode => "SINGLE_PORT",
outdata_reg_a => "UNREGISTERED",
indata_aclr_a => "NONE",
wrcontrol_aclr_a => "NONE",
address_aclr_a => "NONE",
outdata_aclr_a => "NONE",
init_file => "example.mif",
lpm_hint => "ENABLE_RUNTIME_MOD=NO",
lpm_type => "altsyncram"
PORT MAP(
wren_a => MW,
clock0 => NOT(CLOCK),
address_a => MEM_ADDR,
data_a => AC,
q_a => MDR
PC_OUT <= PC;
AC_OUT <= AC;
MDR_OUT <= MDR;
MAR_OUT <= MEM_ADDR;
IO_WRITE <= '0';
IO_CYCLE <= '0';
IO_ADDR <= IR(7 DOWNTO 0);
WITH STATE SELECT
MEM_ADDR <= PC WHEN FETCH,
IR(9 DOWNTO 0) WHEN OTHERS;
PROCESS (CLOCK, RESETN)
BEGIN
IF (RESETN = '0') THEN -- Active low, asynchronous reset
STATE <= RESET_PC;
ELSIF (RISING_EDGE(CLOCK)) THEN
CASE STATE IS
WHEN RESET_PC =>
MW <= '0'; -- Clear memory write flag
PC <= "0000000000"; -- Reset PC to the beginning of memory, address 0x000
AC <= x"0000"; -- Clear AC register
STATE <= FETCH;
WHEN FETCH =>
IR <= MDR; -- Latch instruction into the IR
PC <= PC + 1; -- Increment PC to next instruction address
STATE <= DECODE;
WHEN DECODE =>
CASE IR(15 downto 10) IS
WHEN "000000" => -- No Operation (NOP)
STATE <= FETCH;
WHEN "000001" => -- LOAD
STATE <= EX_LOAD;
WHEN "000010" => -- STORE
STATE <= EX_STORE;
WHEN "000011" => -- ADD
STATE <= EX_ADD;
WHEN "000101" => -- JUMP
STATE <= EX_JUMP;
WHEN "001001" => -- AND
STATE <= EX_AND;
WHEN "000100" => -- SUB
STATE <= EX_SUB;
WHEN "000110" => -- JNEG
STATE <= EX_JNEG;
WHEN "000111" => -- JPOS
STATE <= EX_JPOS;
WHEN "001000" => -- JZERO
STATE <= EX_JZERO;
WHEN "001010" => -- OR
STATE <= EX_OR;
WHEN "001011" => -- XOR
STATE <= EX_XOR;
WHEN "001101" => -- ADDI
STATE <= EX_ADDI;
WHEN OTHERS => -- Invalid opcodes default to NOP
STATE <= FETCH;
END CASE;
-- INDIVIDUAL EXCUTE STATES
WHEN EX_LOAD =>
AC <= MDR; -- Latch data from MDR (memory contents) to AC
STATE <= FETCH;
WHEN EX_STORE =>
MW <= '1'; -- Raise MW to write AC to MEM
STATE <= EX_STORE2;
WHEN EX_STORE2 =>
MW <= '0'; -- Drop MW to end write cycle
STATE <= FETCH;
WHEN EX_ADD =>
AC <= AC + MDR;
STATE <= FETCH;
WHEN EX_JUMP =>
PC <= IR(9 DOWNTO 0);
STATE <= FETCH;
WHEN EX_AND =>
AC <= AC AND MDR;
STATE <= FETCH;
WHEN EX_SUB =>
AC <= AC - MDR;
STATE <= FETCH;
WHEN EX_JNEG =>
IF AC(15) = 1 THEN --<------- ERROR IS HERE
PC <= MEM_ADDR;
STATE <= FETCH;
END IF;
STATE <= FETCH;
WHEN EX_JPOS =>
IF AC(15) = 0 THEN
PC <= MEM_ADDR;
STATE <= FETCH;
END IF;
STATE <= FETCH;
WHEN EX_JZERO =>
IF AC(15 downto 0) = "0000000000000000" THEN
PC <= MEM_ADDR;
STATE <= FETCH;
END IF;
STATE <= FETCH;
WHEN EX_OR =>
AC <= AC OR MDR;
STATE <= FETCH;
WHEN EX_XOR =>
AC <= AC XOR MDR;
STATE <= FETCH;
WHEN EX_ADDI =>
AC <= AC + "0000000000000001";
STATE <= FETCH;
WHEN OTHERS =>
STATE <= FETCH; -- If an invalid state is reached, return to FETCH
END CASE;
END IF;
END PROCESS;
END a;
