12 years agoError while trying to program EPCS flash in indirect SFL mode
(editing my previous thread for an update and save make the thread becomes blank, so I'm re-posting it as a new thread here)
Hi, On my new CoreEP4CE10 board, I'm able to upload designs successfully in FPGA Ram using JTAG, but I'm unable to program EPCS Flash using JTAG Indirect SFL mode. Since this board doesn't have an AS connector, I have no other choice to program using SFL, so I decided to try at command-line, but I got same problem : We can see below that SFLoader is actually succesfully loaded, but then the JTAG hang and the EPCS is not detected. Question : Are all boards using same FPGA are compatible with those SFL "Factory default enhanced SFL image" provided ? Should I try to make my own loader using SFL Megafunctions ? Info: ******************************************************************* Info: Running Quartus II 64-Bit Programmer Info: Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Web Edition Info: Copyright (C) 1991-2013 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, Altera MegaCore Function License Info: Agreement, or other applicable license agreement, including, Info: without limitation, that your use is for the sole purpose of Info: programming logic devices manufactured by Altera and sold by Info: Altera or its authorized distributors. Please refer to the Info: applicable agreement for further details. Info: Processing started: Wed Feb 19 12:11:02 2014 Info: Command: quartus_pgm -m JTAG -o pi;output_files/blinker.jic Info (213045): Using programming cable "USB-Blaster(Altera) [1-1.3]" Info (213011): Using programming file output_files/blinker.jic with checksum 0x1A5AF94D for device EP4CE10@1 Info (209060): Started Programmer operation at Wed Feb 19 12:11:03 2014 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x020F10DD Info (209007): Configuration succeeded -- 1 device(s) configured Error (209037): JTAG Server can't access selected programming hardware Error (209012): Operation failed Info (209061): Ended Programmer operation at Wed Feb 19 12:11:26 2014 Error: Quartus II 64-Bit Programmer was unsuccessful. 2 errors, 0 warnings Error: Peak virtual memory: 286 megabytes Error: Processing ended: Wed Feb 19 12:11:26 2014 Error: Elapsed time: 00:00:24 Error: Total CPU time (on all processors): 00:00:00 UPDATE : Following instruction of the Troubleshooting page (http://www.altera.com/cgi-bin/ts.pl?fn=configuration&hi=2-8), I've manually uploaded the SFL into the FPGA, then I've performed an antodetect again, and I'm unable to see the EPCS, I'm only seeing the FPGA itself. Doing the same at the command-line "jtagconfig" only shows the FPGA where I presume the EPCS should also appear, but it doesn't ... I've check power supply voltages, they look fine ... Is that mean my USB Blaster is defective (but why I'm able to upload FPGA properly) ?
