Monique_Parrish
3 years agoError tcl script (questa)
I am trying to open a do file in questa but the error is can't open the library?
I installed questa and got the license from (SSLC) and it works. I also opened the directory and found the file but ...
ShengN_altera
3 years agoHi,
In Quartus Standard, go to Assignments -> Settings -> Simulation -> More EDA Netlist Writer Settings -> Generate third-party EDA tool command script for RTL functional simulation (on) -> Include test bench in Compile test bench: box -> run full compilation -> should see .do file auto generated in .../simulation/questa directory. Try to run the .do file and see the error still persist? (Note: remember to include the .sip file for compilation if there's any).
Also can try nativelink simulation should be no error given.
Sheng
