17 years agoError 10479 : Indexed name type is used but not declared
Hi Guys,
Trying to run the code below gives me Error 10479 : Indexed name type is used but not declared at line 13 (The Function Return line). I'm a beginner in VHDL, but as I understand you don't need to separately declare a return variable or am I wrong? If so, how and where would I do that? library ieee; use ieee.STD_LOGIC_1164.ALL; use ieee.STD_LOGIC_ARITH.ALL; use ieee.STD_LOGIC_UNSIGNED.ALL; entity bcdadder is port ( SW : IN STD_LOGIC_VECTOR (9 downto 2); HEX0, HEX1, HEX2, HEX3 : OUT STD_LOGIC_VECTOR (0 to 6); KEY3 : IN STD_LOGIC); -- FUNCTION to convert binary to bcd function binarytobcd (binary_n : INTEGER RANGE 0 TO 15) return STD_LOGIC_VECTOR (7 downto 0) IS < ERROR Line VARIABLE out_v : STD_LOGIC_VECTOR (7 downto 0); VARIABLE out_tem : INTEGER RANGE 0 TO 15; begin if (binary_n >= 10 and binary_n < 20) then out_v (7 downto 4) := "0001"; elsif (binary_n >= 20 and binary_n < 30) then out_v (7 downto 4) := "0010"; elsif (binary_n >= 30) then out_v (7 downto 4) := "0011"; else out_v (7 downto 4) := "0000"; end if; if (binary_n >= 10 and binary_n < 20) then out_tem := binary_n - 10; elsif (binary_n >= 20 and binary_n < 30) then out_tem := binary_n - 20; elsif (binary_n >= 30) then out_tem := binary_n - 30; else out_tem := binary_n; end if; out_v (3 downto 0) := conv_std_logic_vector(out_tem, 4); return out_v; end function binarytobcd; end bcdadder; architecture logic of bcdadder is signal out_i: INTEGER RANGE 0 TO 30; signal out_bcd, out_bcd2, out_bcd3, out_bcd4 : STD_LOGIC_VECTOR (3 downto 0); signal a, b : INTEGER RANGE 0 TO 15; signal outter, outera, outerb : STD_LOGIC_VECTOR (7 DOWNTO 0); --COMPONENT INSTANTIATIONS COMPONENT BCD2LED PORT ( D:IN STD_LOGIC_VECTOR(3 DOWNTO 0); O:OUT STD_LOGIC_VECTOR(6 DOWNTO 0)); END COMPONENT; begin BCD1 : BCD2LED PORT MAP (out_bcd, HEX1); BCD2 : BCD2LED PORT MAP (out_bcd2, HEX0); BCD3 : BCD2LED PORT MAP (out_bcd3, HEX2); BCD4 : BCD2LED PORT MAP (out_bcd4, HEX3); a <= conv_integer(unsigned(SW(9 downto 6))); b <= conv_integer(unsigned(SW(5 downto 2))); out_i <= a + b; switch_on : PROCESS (KEY3) begin outter <= binarytobcd (out_i); outtera <= binarytobcd (a); outterb <= binarytobcd (b); if KEY3 = '0' then out_bcd2 <= outter (3 downto 0); out_bcd <= outter (7 downto 4); out_bcd3 <= "XXXX"; out_bcd4 <= "XXXX"; else out_bcd <= outterb (7 downto 4); out_bcd2 <= outterb (3 downto 0); out_bcd3 <= outtera (3 downto 0); out_bcd4 <= outtera (7 downto 4); end if; end process switch_on; end logic;
