Does Quartus 13.1 pro supports Intel-FPGA-Quartus-RSA-1 RTL encrypted code?
I've seen in another forum that Quartus pro supports the RTL encrypted with Intel-FPGA-Quartus-RSA-1.
But I have the impression it is only supported by quartus prime and not quartus pro.
The problem is that I use a Stratrix 3 FPGA and cannot use any new version of quartus than 13.1.
Quartus pro 13.1 gives an error at the line 3 of reading the encrypted verilog code which is:
`pragma protect begin_protected
`pragma protect version=1
error:
Critical Warning (10191): Verilog HDL Compiler Directive warning at __defines.vh(2): text macro "pragma" is undefined
Error (10170): Verilog HDL syntax error at __defines.vh(3) near text "protect"; expecting ";"
Later on the file there are references for quartus (are they understood by quartus prime?):
`pragma protect key_keyowner="Intel Corporation"
`pragma protect key_keyname="Intel-FPGA-Quartus-RSA-1"
`pragma protect key_method="rsa"
`pragma protect encoding = (enctype = "base64", line_length = 76, bytes = 256 )
`pragma protect key_block
n0UPGPFspR1ysbje0ATJO017usMhu6rHITQH+dT3Twom+D...
I was planning to use Synplify to create the gate netlist but the output is encrypted in the vqm,
which also gives error with quartus.
Alex.
- AEsqu
Contributor
Apparently the support was introduced at Quartus Pro 17.1,
can you confirm?
- RichardT_altera
Yes, you are right.
IEEE 1735 Encryption Standard is only supported in Quartus Prime Pro Edition. Quartus Standard/Lite does not support it unfortunately.
- RichardT_altera
I believed I have answered your question. With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos and select the best solution.
