Does Checksum differ for two SOF files generated with same RTL and same seed
- 4 years ago
Ok, so have to modify my answer a bit.
I am using Quartus Web 13.0sp1 on a Win10 platform.
So if I delete all the generated design files, and rerun the the compilation from scratch, a SOF with a different CRC32 is built each time.
If I just 'remake' the design by recompiling without deleting the existing design database files, a SOF with the same CRC32 is built each time.
But, in all instances, the final POF/JIC files I use, that are built from the SOF, ALWAYS have the same CRC32 value after each recompile.
And of course if I do a verify of an existing programmed part using the JIC file vs EEPROM contents, it matches 100%.
So it looks like there may be some data within a SOF that may vary from compile to compile, but it is not included when the JIC is built.
Just my observation, I have no inside knowledge other than being a user.
So comparing POF or JIC file CRC32s seems ok, but the CRC32 of the SOF is not.
Thanks for the inputs.
Following link also confirms that Checksum is not same on the sof file as it contain timestamp information.
https://www.intel.com/content/www/us/en/support/programmable/articles/000080266.html
Resolution To ensure the designs are identical, perform an MD5 checksum or diff on the Programmer Object File (.pof) or the Raw Binary File (.rbf) which does not contain timestamp info.
Siva Kona
