Does Checksum differ for two SOF files generated with same RTL and same seed
- 4 years ago
Ok, so have to modify my answer a bit.
I am using Quartus Web 13.0sp1 on a Win10 platform.
So if I delete all the generated design files, and rerun the the compilation from scratch, a SOF with a different CRC32 is built each time.
If I just 'remake' the design by recompiling without deleting the existing design database files, a SOF with the same CRC32 is built each time.
But, in all instances, the final POF/JIC files I use, that are built from the SOF, ALWAYS have the same CRC32 value after each recompile.
And of course if I do a verify of an existing programmed part using the JIC file vs EEPROM contents, it matches 100%.
So it looks like there may be some data within a SOF that may vary from compile to compile, but it is not included when the JIC is built.
Just my observation, I have no inside knowledge other than being a user.
So comparing POF or JIC file CRC32s seems ok, but the CRC32 of the SOF is not.
Thanks for your inputs.
I have run two SOF build runs consecutively one after the other with same seed ( set_global_assignment -name SEED 16) and with no changes in RTL.
I could NOT compare the .sof files. Instead, I have compared the checksums of .sof files and the checksum values are different.
CTH-ip-gyann> md5sum e1_gyann_fpga_top_s10/quartus/par_results/gyann_fpga_top_demo1.sof
c3405c1e3ab219c1edd5bd168cb45c70 e1_gyann_fpga_top_s10/quartus/par_results/gyann_fpga_top_demo1.sof
CTH-ip-gyann> md5sum e2_gyann_fpga_top_s10/quartus/par_results/gyann_fpga_top_demo1.sof
df42a66fbcd44459e55aa9fe4466bfe0 e2_gyann_fpga_top_s10/quartus/par_results/gyann_fpga_top_demo1.sof
Except Time stamp, elapsed time and System Process Id, everything else matches in all fit and asm reports. But we see the checksums mismatch between sof files .
Could you please share your thoughts on this ?
Siva Kona
