alex_ander
4 years agodetermining set input and set ouput delay values
Hello
I am working with understanding the timing analyzer and I have a question regarding the delay values themselves that would be used for the set_input_delay and set_output_delay. I understand s...
SyafieqS
4 years agoAlex,
The value is referred to a data specification sheet for device you used. You may find all setup time, hold time to determine the input and output delay. You can refer to a part in datasheet called IO timing and there, you may find the parameter and value desired.
