15 years ago --- Quote Start --- Ok.. Finally My Control Panel WORKS.. What I did was removed.. Everything Quartus 7.2 as well as 9.0 Then Installed 9.1 with NIOS Then Downloaded the .sof on the board using Quartus Programmer tool Then Opened NiosDOWNLOAD BATCH Then opened Control Panel .. Downloaded the code on it And it connected --- Quote End --- What is quartus programmer tool? Is it the Quartus II web edition software that comes with the kit? If so how do you load .sof file to FPGA using this software? I will appreciate your help very much.
