9 years agoDDR2_SDRAM Interface to Cyclone-3 device
Hi I have downloaded this attached code. This code pin assignment is not matching with our board pin assignment, so I just removed the .qsf file and run again to do the pin assignment as per ou...
9 years agoThis mean you do not have official license for the IP core, you can contact you local FAE to get the license for this IP and compile is without error. Otherwise, as recommend by sstrell, you have to connect the JTAG when validating or using the IP.
