13 years ago --- Quote Start --- But in this case I have to use DIFFIO_xxn to assign my signal port MYSIG. --- Quote End --- "I have to" is bad when it refers to impossible things. I guess, you are trying to fix an error in schematic design? You need to invert the signal somewhere in the logic fabric. If a LVDS receiver/transmitter is connected to the pin, invert the parallel data.
