13 years agoAccording to the error message, the positive pin is B18, not A18. So the reason is that you assigned the wrong pin. You always need to assign the DIFFIO_xxp pin of a differential pair.
--- Quote End --- Hi, I will assign my signal to DIFFIO_xxp if I design from scratch. But in this case I have to use DIFFIO_xxn to assign my signal port MYSIG. Quartus II automatically create MYSIG(n) on pin DIFFIO_xxp. If so, why the tool also complain with Error??? It is a little strange. Is there a option in Quartus to allow me to assign differential signal with inversion: positive port to negative pin, negative port (autogenerated by Quartus) to positive pin? Thanks a lot !
