13 years ago --- Quote Start --- I did so by using the mini lvds protocol, and there Quartus let me assign the differential pairs manually. --- Quote End --- What do you exactly mean by this? What happens, if you assign the positive pin only? Does Quartus omit the negative pin? --- Quote Start --- So for my signal - MYSIG on A18, I see MYSIG(n) created on B18 for me automatically. --- Quote End --- According to the error message, the positive pin is B18, not A18. So the reason is that you assigned the wrong pin. You always need to assign the DIFFIO_xxp pin of a differential pair.
