sphilipp
4 years agoConnect external clock via non-dedicated pin to PLL on Cyclone 10 LP
Hi everyone
I have a PCB that I cannot change, on which a clock is connected to a non-PLL-dedicated pin. I was indeed trying to use a PLL, but Quartus 20.1.1 Lite software hinders to connect the PLL ...
sstrell
4 years agoDo you need to go through the clock control block? You should be able to connect an internal design signal directly to a PLL input.
