8 years agoConfusion about data type alignment
I need to transfer 128 structures from host to FPGA. In the host code,I define the structure as following:
*********************************************************************# define AOCL_ALIGNMENT 64 typedef struct { double S; double X; double u; double e_rt_p; double e_rt_q; int CP; }struct_A; struct_A* input_A; input_A=(struct_A *)_aligned_malloc(128*sizeof(struct_A),AOCL_ALIGNMENT); *********************************************************************** in the kernel code,I define the structure as following: ********************************************************************** typedef struct __attribute__((packed)) __attribute__((aligned(64))) { double S; double X; double u; double e_rt_p; double e_rt_q; int CP; }struct_A; __kernel void kernels(__global double* restrict output_data, __global struct_A* restrict input_data) for (int i=0;i<128;i++){ S = input_data.S; X = input_data.X; u = input_data.u; e_rt_p = input_data.e_rt_p; e_rt_q = input_data.e_rt_q; CP = input_data.CP; } ************************************************************************************* BUT, I can't get the values of S~cp in right order, when I remove "__attribute__((packed)) __attribute__((aligned(64)))", I can get the right values of S~cp. Can anyone figure out what's the problem in my code?Thanks very much.No RepliesBe the first to reply
