Compilation Internal Error Quartus 9.1
- 4 years ago
Thanks for the response Sheng. Sorry, I couldn't provide the source due for proprietary reasons.
I found the cause of that quartus internal error. I had removed a design component that isn't required anymore to free up resources (it is in the SOPC table of connected components), but I could still find it in the quartus settings file. Apparently, it was defined as a design partition (possibly for incremental compile reasons?). I’m not the original designer, so I’m not aware of the design decisions that went into setting that up. I deleted it from design partition table, then I could compile successfully. Would have been nice if tool had indicated “invalid design partition” instead of “internal error”. Regards, Grady
Could you provide a sample file which duplicates the internal error for testing?
Sheng
