UMall1
4 years agoClock PLL error
I use a PLL in my FPGA - EP3C80F484C6N. I am receiving the following warning from Quartus.
Warning (15899): PLL "SENSOR_CLOCK:U_SENSOR_CLOCK|altpll:altpll_component|SENSOR_CLOCK_altpll:auto_generated|pll1" has parameters clk1_multiply_by and clk1_divide_by specified but port CLK[1] is not connected
What does this message mean? I simulate the module and see that all derived clocks are present and correct.
Udayan Mallik
- ak6dn
Quartus detects that you entered some configuration parameters for the CLK[1] output but you don't actually use CLK[1].
It's a WARNING, you can ignore it.
- Ash_R_Altera
This Warning is received when the output of the PLL is unconnected. Refer the Quartus Help link below:
