alxb
5 years agoCIC filter license
Hello!
I'm using Quartus 14.1 and I want to know am I need a license for CIC filter from IP catalog which will give guarantee that design will not be limited in time after programming FPGA?
Also ...
Zawani_M_Intel
5 years agoHi ,
I will send you a private message to get the .dat file.
Thanks!
Wani
- Carlota4 years ago
Hi!
I think I must have the same problem as you are discussing in this message thread.
I am running a project containing the CIC element which has a time limited. The .sof file is created correctly and I can use it successfully.
But this last week I installed Quartus (same version and same license) on another computer and when compiling the same project the .sof file is not created giving an error in the CIC component.
What could be the problem?
Thank you very much and best regards,
Carlota
