9 years agoCan't instantiate Signal Tap using megafunction tool in Quartus 17.0.1
I am attempting to instantiate a signal tap core using the megafunction flow. Quartus generates the IP but when I instantiate it in my project and compile I get the following error. Error(1378...
SDe_J
7 years agoI having this same error in quartus 18.0, and the suggestions here have not solved it. Is there anything else I should try?
- designEngineer4 years ago
When generating the IP make sure to chose Verilog as the output. The module can be instantiated as either Verilog or VHDL but when generating the IP, if choosing VHDL instead of Verilog as the output I get this error. Using Verilog as output fixed the issue for me.
