9 years agoCan't instantiate Signal Tap using megafunction tool in Quartus 17.0.1
I am attempting to instantiate a signal tap core using the megafunction flow. Quartus generates the IP but when I instantiate it in my project and compile I get the following error. Error(1378...
8 years ago --- Quote Start --- For one thing, your instantiation is incorrect. You have the word "component" in there. It should just be: signal_tap_inst: signal_tap port map ( What happens when you remove "component"? --- Quote End --- Yes, you had to remove the component. Even though Quartus does not error on this.
