SivaKona
4 years agoCannot place ALERT# in DQS group Error for External Memory Interfaces Intel Stratix 10 FPGA IP
We are working on Quartus Version : Quartus Prime Version 21.1.0 Build 169 03/24/2021 SC Pro Edition
Target Device: 1SG280HU2F50E2VG
Added "External Memory Interfaces Intel Stratix 10 FPGA ...
sstrell
4 years agoAs noted, did you synch the system infos after you made the parameter change? Just click Sync System Infos at the bottom of Platform Designer.
SivaKona
4 years agoHi sstrell,
"Sync System infos" also did not change the behavior. Got same Errors as before.
Following is the snapshot of the messages around first Error
Siva Kona
